Full Version: Reflections after 6 months ownership
After 6 months of ownership here are my reflection on my 306tdi. It's comfortable, easily keeps up with much newer cars, is incredibly economical, with the rear seats folded down it holds a good amount of stuff and tows my trailer with no effort.
It only needed 2 wiper blades to pass the MOT but there were no other advisories, the tester even commented on how clean it was underneath, probably a result of spending the greater part of its life in the South of France.
When I first got it it was difficult to start and chucked out clouds of smoke for about 10 seconds. A little diagnosis showed only one of the heater plugs was working so they were replaced (what an awkward little job). It now starts first turn of the key and no smoke. The only other job was resurrecting the dead and damaged remotes, I've done one of them to date and plan doing the second during the next week or so. Again this was not the straightforward job I was expecting but now works as it should. The main problem was not being able to get the correct case so a few modifications were required, the next one will be much quicker.
One downside is the number of rattles and vibrations which seem mainly to be caused by loose fitting trim panels and I'm working through them but there is a rattle/vibration from the boot area I still can't find.
Good to see a new member enjoying their 306, they're great little cars. Hope you stick around, post a project thread so we can keep up with your work!
Theyre perfectly usable as a current day car. Its just the road noise and safety thats the real issue :/ Glad to see youre enjoying it Smile
Is the safety that poor that it poses a real issue?
All pre-2001 cars are now designated as 2 star safety according to NCAP
would that rattle be from underneath?
I've currently got a loose disc shield causing mine. (knees too stiff to spanner)
