Hi, has anyone with the 1.4 meridan changed the gearbox for better acceleration. And does the 106 quicksilver gearbox fit. I was told it would change the ratio and lose top end which I'm not fussed about. Or does anyone have a recommendation on which box would be an upgrade for the standard box.
Cheers Harvey
I fitted a 206 one, more for the reason that the old box was knackered. I think it's got a slightly longer third.
Don't think you'll massively improve a 1.4s acceleration with a shorter box though.
I fitted a slightly later 1.4 one that had a lower final drive which helped somewhat - 4.54 vs the original 4.29 - but mine was a single linkage box, not the late 3 linkage, so my options were pretty limited. It was really only because the box was perfect inside versus looking at many that were half shot.
(04-03-2019, 05:16 PM)Alan_M Wrote: [ -> ]I fitted a 206 one, more for the reason that the old box was knackered. I think it's got a slightly longer third.
(05-03-2019, 04:59 PM)Rippthrough Wrote: [ -> ]I fitted a slightly later 1.4 one that had a lower final drive which helped somewhat - 4.54 vs the original 4.29 - but mine was a single linkage box, not the late 3 linkage, so my options were pretty limited. It was really only because the box was perfect inside versus looking at many that were half shot.
I think you deleted your message by mistake there
(06-03-2019, 12:27 AM)Rippthrough Wrote: [ -> ]I think you deleted your message by mistake there
... doh
