20-11-2018, 07:51 PM
I've finally bought the car I've dreamed of owning since I was a kid- an Impreza WRX.
Totally unmodified other than a quiet backbox because the original needed replacement, 89k miles, FSH, nearly 12months MOT and the correct colour etc. It's generally in pretty good condition.
I'm not driving it yet- still in the old daily Fiesta 1.6 tdci for now. However I've obviously test-driven it and driven it a fair way home from buying it, plus on local roads a bit. Eventually that'll go and this will be my daily.
Immediate plans are to do the cambelt, water pump and tensioners and any other servicing and maintenance it needs before it goes on the road, plus probably a turbo up-pipe as they stop the pre-turbo cat disintegrating and blowing through the turbo, help the turbo to spool earlier, are worth 5-10hp according to forums and dyno graphs etc. and are a PITA to change so easier to do it now while it isn't in daily use yet. Then potentially the mid-section of the exhaust between the cat/downpipe and the backbox to free it up even more and make it sound a little better. Don't want it silly loud but more bhp and little more noise would be good.
Eventually probably set it to pro-drive geometry settings and map it once exhaust and any other supporting modifications are done. Definitely want to get it tip-top mechanically and cosmetically first.
