I’m struggling to source the cup that links the subframe arm to the chassis leg.
Avoided removing the subframe on a refurb till now for just this reason. Rusted to buggery and the nut is now spinning.
Any body got one of each in half decent condition?
I should have, do you just need one or a pair? I'll try and look this weekend.
A pair would be great man. I can get the nuts/bolts new from Peugeot.
Let me know frosty! Cheers pal.
(10-08-2018, 08:19 AM)doogle-d turbo Wrote: [ -> ]A pair would be great man. I can get the nuts/bolts new from Peugeot.
Ok i'll be having a look tomorrow
Sorry i didn't get round to having a look through my boxes of spares etc on the weekend. Are you in much of a rush for them?
No major rush, the car is in bits. I may have found some new if you can’t find any.
I've found some caps and the captive nut bit. Is it both bits your wanting? i can also sort a few bolts if need be?
If you can do the cups and the nuts (the square captives) that would be great. If you have the 2 bolts that go on them too? I can re use the 4 that hold the cups to the under chassis.
Will try and sort them out tomorrow and ill then drop you a message
Cheers mate
