Full Version: Wheels offset
Hi guys,
Recently I started to think about getting my hands on some 15' alloys - I found a set of nice looking ones but there is one problem - offset Speechless .
From what I heard this Pugs needs about 15mm with 6,5" alloy width - the ones I found have 35 offset on 6,5".
Do you have any experience on mounting alloys with such high offset in 306?
They will rub the inner arches badly if they fit, but they probably just won't fit at all. To run them you would need 20mm hubcentric spacers and a set of matching longer bolts. Don't forget to check the centre bore matches, if it doesn't you can always get hubcentric spacers with staggered spigot/bore size.
