Evening All,
Today I noticed that suddenly the gears were a lot more notchy than I am used to. On the way to work this morning I drove through a fairly deep flood across the road. Do you think it could have got in the gearbox and now would need an oil change? Is it able to get in there?
Seems really coincidental if that's not the cause..
Any ideas?
Thanks,
Jack
The oiled part of the gearbox is sealed as far as im aware apart from a breather but thats ontop of the gearbox so i doubt anything has got in! See what happens over the next few days?
Try greasing the ball joints on the gear linkages. If that doesn't work I'd be changing the box oil as a precaution.
So over the next day and a half it has gone back to normal! These cars are strange! I will probably do the gear oil soon anyway just as a general refresh of it.
I will also look at greasing the joint linkages as well
Cheers guys
Also worth putting a bit of lube on the rubber ball that the metal sleeve thing sits on above the steering rack while you've got the grease out.
haha I will have a look for the metal sleeve thing as well
Cheers
What is the recommended gear oil for these cars again? I have forgot and only seem to find a lot of people arguing when I google it! haha. I believe it was shell of some sort? 85w90 or something?
Just get it from peugeot, isn't any more expensive than anywhere else. Total 9000 quartz or something like that. I'm sure welshpug can correct me.
75w80, or the new stuff is straight 75w, definitely get it from peugeot unless there's a Motaquip factors locally that does total.
make sure it is not EP oil.
it may be the clutch self adjuster as that is on the lowest point of the cable, if that got full of water and mud then it could have altered the bite point.
Nice one guys cheers
The issue has gone away and hasn't returned yet so I am guessing it was somehow related to the flood :/ Either way it seems much better so all is good now
