08-12-2017, 03:20 PM
quick guide on how to get out andĀ replacing a oil seal on a crank
[attachment=31156]
locate oil leak strip down to expose damaged sealĀ
[attachment=31157]
drill small hole in seal casing maybe 2 at 180degs
[attachment=31158]
insert screw and slowly screw into the seal which should start to press the seal out of the housing if this dont work add a second screw at 180 degrees and use both to press seal out
[attachment=31159]
[attachment=31160]
[attachment=31161]
refit new seal buy tapping into position
check all faces and reasemble
[attachment=31162]
[attachment=31156]
[attachment=31157]
[attachment=31158]
[attachment=31159]
[attachment=31160]
[attachment=31161]
[attachment=31162]
