The cigarette lighter port in my car is annoying me. It won't work with any USB adaptors I put into but I know it's working as it will still run the tyre inflator just fine.
The one I use right now would work intermittently with it at first, but now not at all. Has anyone else had this problem?
It's a Ph3 and I have a Ph2 port spare but the connectors are different so wasn't sure about cutting cables and bodging it on with connectors. Could I just cut the wiring and use connectors like these?
https://www.maplin.co.uk/p/maplin-miniat...pack-n22an
Ive had an issue butt he issue was with the usb adapter. The bottom contact isnt long enough to actually touch the contact in the socket. If you have this issue it explains why the pump is working but the others are not. Put some bluetack on the bottom and see if it comes back out with a mark? Dont put your fingers in though!
Remember you want at least 2.1A charging for a USB adapter to be worthwhile otherwise itll use up the power fast than it charges.
(07-11-2017, 04:09 PM)Eeyore Wrote: [ -> ]Ive had an issue butt he issue was with the usb adapter. The bottom contact isnt long enough to actually touch the contact in the socket. If you have this issue it explains why the pump is working but the others are not. Put some bluetack on the bottom and see if it comes back out with a mark? Dont put your fingers in though!
I'll give that a try. I've tried 3 different ones and none work, annoyingly.
As for the power level, I'm using an Anker 2 port that does 2.4A. Used it at work to power an SJ4000 as a dashcam and dash charge a OnePlus 3 so I'd really like to make it work.
what anker model is it? I bought two of them and they immediately replaced both of them with a better model which had a longer bottom pin!
My new dashcam turned up today and the charger that came with seems to work. 2 port 3.1a output so I guess the problem is solved for now.
