12-08-2017, 06:58 PM
Well here goes
BREAKING PEUGEOT 306 GTI6 TURBO.
now this isnt a bitch fight it isnt a discussion between people. Its a list of stuff for sale at a fair price and it is fair. As soon as the engine and gearbox sells either as a package or induvidually the rest will also be for sale.
So.
Engine and gearbox package. 8K
Fully forged turbo charged 2046cc low comp engine.
Spoox time attack spec gearbox with 3j lsd and 205 1900 cwp.
Full boost circuit including ic and dv and boost controller.
Full water circuit including rad and hard pipe kit.
Full 3" exhaust system circa 89-92db.
Full wiring complete with fuses and relays and ecu etc.
Helix paddle clutch complete.
All the engine mounts.
Full fuel system including 044 swirl pot fpr fuel filter etc.
Oil circuit with sandwich plate and cooler and hoses.
All the guages which are all stack. Afr boost and egt.
Carbon rocker cover
Basically anything to make the car drive. There is a load more that i can add. If intrested pm me.
I can break it down into an 5k engine 3k gearbox package but i would need a buyer for each package.
Suspension
Front
Bc racing coil overs with baker bm top mounts 18mm hubs and gen wishbones with vibra technic p bushes £450
Rear
Bc racing dampers solid mounts and beam consisting of bridgcraft arms o toe and neg 3 camber 30mm arb and 24mm torsion bars £650
Brakes
Front
Tarox 10 pots 330 discs will come with braided lines £900
Rear
Standard calipers wavy discs and new ds2500 also will include braided lines £200
Tilton lever bias valve £50
Wheels
17" Oz leggenda x4 in black with nearly new ad08r £750
17" oz superturismo gt (i think) in black with avon zzr fronts and khumo v70 on rear £400
Body and bits
Bare shell with light loom cage and harness bar seat mounts carbon drivers foot well carbon flap inserts £300
Corsa epas conversion £200
Doors with carbon door cards and carbon door handles manual window winders £100 each
Fire ectinguisher system including hand held and fixed as per msa spec £100
Brian james twin axke tilt trailer with all the straps etc £1200
LIKE I SAID LOADS AND LOADS THERES EVEN MORE THAT I WILL GET PICS UP OF.
Serious posts only please
So.
Carbon rocker cover
Suspension
Front
Rear
Brakes
Front
Rear
Wheels
Body and bits
