22-07-2017, 11:56 AM
TBH, this probably isn't a 306 specific question. Both Haynes and Peugeot's own repair procedures recommend replacing the front carrier mounting bolts and the front & rear caliper mounting bolts each time they're disturbed. I've only bothered to replace the front caliper slider bolts (M8's x 20mm) as I already had some lying around.
I assume most garages don't ever bother fitting new ones as in the past when I've had brakes done I've never seen a set of new caliper mounting bolts on an invoice!
What do most of you do or recommend?
Cheers
Cheers
