29-05-2017, 07:38 PM
So ive had the dash out of the kingfisher for a couple of weeks now to weld up everything. Put the dash back in and the battery light is on! Plus as an added insult it also seems like the acc is switched in the ignition barrel so wipers work etc while ignition is off. The barrel can be disconnected and this still happens.
The earth is good under the dash have checked
Everything works as it should when the igntion is on
Alternator has been repaced as i thought it had shorted
Earth straps in bay have been changed (broke while doing matrix pipes)
The chassis leg connectors are
Immaculate no corrosion at all
There are two connectors that look like they should be plugged in but are not they are pictured. The brown is passenger side foot well and the white is drivers footwell. ANY ideas please?
[attachment=29945][attachment=29946]
