20-05-2017, 01:58 PM
The time has come to be realistic about how many projects i can manage at once and my much-loved 205 is currently bottom of the pile, so here she is up for sale. I've owned her for 4 years, during which time i spent a fair amount of time and money fixing the major problems. However, having had her up on a ramp today to refresh my memory, i've decided the rust is too much for me to deal with, so i'm now selling as spares or repairs. It's not irreparable by any means, the issue is the standard fare for 205s, ie both rear sills rotted out with it spreading up and forwards a bit. I've taken a few photos - see below - bear in mind that's as she's been stood for the last few months, uncleaned, unmoved, didn't even pump the tyres up.
She is a 205 STDT in Oberon green. Currently 181 of the STDTs left in total, so she's a pretty rare beast. However, 139 of those are listed as sorn so the chances are half of them are already beyond repair/scrapped and never to see the light of day again. At some point in her past one of the former owners has fitted a GTi bodykit and speedlines, hence her current appearance. As with most rare cars of this age, the price is only going up; i always intended to keep her as investment but have run out of driveway space and rather need the liquid cash.
During my ownership she has had a fair few hundred spent and all sorts of repair and improvement work done, some of which i have receipts for. This is including, but not limited to: driveshafts, timing belt and water pump, clutch, aux belts, rocker cover gasket, all fluids flushed and replaced, various filters and sump plug (oil changed at 8k intervals or less), drop links, shocks, lower arms, tie rods, glow plugs, alternator, wheel bearings, washer pump, door seal, steering column UJ, wing mirror and handle, battery, brake hoses, exhaust mounts, door check-strap, various bits of hose, horn, gearknob and gaiter, number plates, aerial, michelin ps3s on the front (still with 7mm or so on them) welding repairs here and there, 306 HDi front brakes and master cylinder (will provide donor reg for future ordering of service parts), tuned xud9t lucas pump and matching injectors with new washers, custom glow-plug relay bypass, custom exhaust using an HDi midbox as the silencer.
She will come with a bunch of spare parts, including, but not limited to: OEM sunroof parts (seals, vac reservoir, gti roof lining, rails, pretty much everything except the glass), one BNIB replacement sill, BNIB heater matrix, BNIB handbrake cables, BNIB brake pads and at least one disc (for original brakes), the original brakes (mc and calipers, with pads), spare steering column, pair of lower arms... can't remember much else off the top of my head, but i'm sure there's lots more, will update when i dig it all out.
Bad points:
- Significant welding repairs required!
- She puts out a bit of blue smoke - suspect turbo, valve stem seals or piston rings.
- Sun-roof is not suitable for the car and has been sealed shut with silicone, hard to explain but will make sense when you view.
- Interior is rather tired, although far from past it. Worst points are the plastics are starting to crack and the roof lining is sagging.
- Can be hard work to start in cold weather, but it does always go with a bit more on the glowies, is yet to actually let me down or even really worry me that much.
[attachment=29902]
[attachment=29903]
[attachment=29904]
[attachment=29905]
[attachment=29906]
[attachment=29907]
[attachment=29908]
She's a great drive, pretty quick when she gets on boost and just so much fun, i'll be extremely sorry to see her go. Sale price is £250 spares or repairs.
Bad points:
[attachment=29902]
[attachment=29903]
[attachment=29904]
[attachment=29905]
[attachment=29906]
[attachment=29907]
[attachment=29908]
