hi all,
just acquired some Laser alloys (thanks Adam) and want to know if;
do the bolts for steelies fit, or are they different?
thanks in advance.
Have a look down the bolt holes, if they're flat you'll need some cyclone wheel bolts, if there's a taper then you'll need to get a tapered set - you can buy full sets tapered and flat seated ones off ebay now
(05-05-2017, 11:24 AM)Midnightclub Wrote: [ -> ]Have a look down the bolt holes, if they're flat you'll need some cyclone wheel bolts, if there's a taper then you'll need to get a tapered set - you can buy full sets tapered and flat seated ones off ebay now
thanks
lasers are only the early type seat, they have long headed bolts not the short cyclone type, though those will bolt on safely they will be a long way down the holes.
