Full Version: Door speaker
While I was driving my right door speaker went out while left door speaker continues to work. What could be the cause? Loosen wires?
I'd like to remove door panel to check the speaker but before that I'll take out radio and check wire connections there first. I'll do it tomorrow but before that I'd like to ask how to exactly remove door panel to reach the speaker? Its a phase 2 Peugeot 306. Or is it possible to take out speaker without removing door panel?
Cheers.
Yes, just pop speaker cover off, few torx to remove then it will come out.
This could be caused by the loom connecting to the door.
Yes, what he said ^^^^^^^ most likely tbh
More than likely the door loom as stated aboveā€¦ Pikey way to test is to remove the speaker and hold the wires to a head phone jack with the radio on and see if you get any sound Wink
youve got the right idea. Check the radio first because its easy and then go for the doors.
