![[Image: f325c1cba823e99dd304d250e572e08d.jpg]](http://uploads.tapatalk-cdn.com/20161127/f325c1cba823e99dd304d250e572e08d.jpg)
Removed this 1.9na out of my peugeot 309 and fitting 306 d turbo lump.
Will I be able to use the 309 thermostat setup and fuel filter on the d turbo engine?
Sent from my SM-G925F using Tapatalk
not sure, Mark Fish will know, as will Sam Barker amongst others, why do you want to? . .
(27-11-2016, 09:28 PM)Mattcheese31 Wrote: [ -> ]not sure, Mark Fish will know, as will Sam Barker amongst others, why do you want to? . .
Just be a case of drop engine in and connect all up instead of changing lines pipework etc
Only one way to find out....
(27-11-2016, 09:32 PM)Piggy Wrote: [ -> ]Only one way to find out....
I just thought I'd ask questions in case anyone already done this
I get that...but you have to remove those items for the swap...so may aswell just take it across to the other engine and see if it fits. Iirc the fuel system is different. Stat opening is different too iirc
Not a 309 but on my bx I swapped from a 1.9 nad to a 1.9 turbo diesel and just transferred the whole cooling system across, thermostat opens at 83c on my nad same as the turbo diesel so swapped that across also.
As piggy and chris say, What I did with my engine conversion even though its a different car, was just use the cars fuel and coolant system.
(28-11-2016, 12:15 AM)Chris_90 Wrote: [ -> ]Not a 309 but on my bx I swapped from a 1.9 nad to a 1.9 turbo diesel and just transferred the whole cooling system across, thermostat opens at 83c on my nad same as the turbo diesel so swapped that across also.
I'll try transfer everything across then it does look very similar
I'll say yes ; most XUD models, NA/t models have very similar stat setups : unsure why you would swap it over though ...
(28-11-2016, 07:21 AM)ginge191 Wrote: [ -> ]I'll say yes ; most XUD models, NA/t models have very similar stat setups : unsure why you would swap it over though ...
I havnt got all the d turbo cooling setup but I have the na so trying to use as much of the na stuff as possible as it's there.
