13-10-2016, 08:18 PM
13-10-2016, 08:32 PM
(13-10-2016, 08:18 PM)KevinTW Wrote: [ -> ]Should there be a gasket between the manifold and CAT or do the springs pull it tight enough? Just pulled the old cat off and no gasket.
There would of been a gasket there, normally stays on the manifold, its a mesh fire ring gasket,
13-10-2016, 08:38 PM
(13-10-2016, 08:32 PM)306gtiparts Wrote: [ -> ](13-10-2016, 08:18 PM)KevinTW Wrote: [ -> ]Should there be a gasket between the manifold and CAT or do the springs pull it tight enough? Just pulled the old cat off and no gasket.
I will take the new cat back off and investigate. Thank you.
