Full Version: rear brake bias replacement
Ok so my zx has rear discs and uses two inline pressure reducers on the rear hardlines - no load compensator.
These are no longer available, or stupidly hard to find / expensive.
Suggestions for replacement?
I'm thinking either using a brake bias valve up near the MC and running new hardlines to rear from one port with a T piece - note would remove diagonal split in system.
Or using a load compensator - maybe just tied up out the way so it doesn't move.
Any suggestions for either?
and for aftermarket brake bias valves?
thanks
same as a late 205/309 so readily available not too expensive.
[attachment=28776]
service box says NFP
part number 1
GSF which I have bought from in past don't seem to stock any longer, or ECP
(10-10-2016, 10:24 AM)welshpug Wrote: [ -> ]same as a late 205/309 so readily available not too expensive.
been nfp for about 15 years lol.
try mr auto.
or a bosch stockist, got mine from one for the zx 16v. shorts auto electrical in cardiff.
will probably need to find the bosch reference number first.
