04-08-2016, 06:24 PM
04-08-2016, 07:32 PM
Tapered Bolts... Do not use flat seated iirc
04-08-2016, 07:50 PM
(04-08-2016, 07:32 PM)BiG K Wrote: [ -> ]Tapered Bolts... Do not use flat seated iirc
wrong, well mostly
flat seated to fit clones. the later ones had flat seated taper that you can just use the flat seated type on as well. hope it helps
04-08-2016, 07:52 PM
clones use flat seated bolts!
there are two types of clones
early/late
early clones take parallel threaded flat seated bolts
later clones take stepped parallel flat seated bolts
later bolts will NOT fit early clones
early bolts fit both types of clones
more info here
http://306oc.co.uk/forum/showthread.php?...#pid329124
early/late
more info here
05-08-2016, 06:09 AM
(04-08-2016, 07:52 PM)cully Wrote: [ -> ]clones use flat seated bolts!Where's the best place to buy them ??
early/late
more info here
05-08-2016, 08:41 AM
forums, facebook, peugeot
05-08-2016, 08:49 AM
hmmm i'm a little worried now... as i've fitted my clones straight on, but didn't have any idea about the nuts issue?
i'm assuming mine are ok being they have gone straight on and bolted up?
05-08-2016, 08:54 AM
Swallow bolts are also flat seated, you should be fine Pocketfighter.
Rob, which wheels do you currently have? A 1.9 HDi doesn't exist so I can't work it out from your car spec lol. The alloys all come with flat seats, steels come with tapered.
As for where to buy them - not Peugeot unless you're feeling rich, the chromed bolts cost £6 each!!
05-08-2016, 09:38 AM
You learn something new every day I guess.... why must Peugeot make everything so complicated!? lol
05-08-2016, 10:05 PM
(05-08-2016, 08:54 AM)Toms306 Wrote: [ -> ]Swallow bolts are also flat seated, you should be fine Pocketfighter.
Sorry 2.0 liter and got steels on. I rang Peugeot and it came to £64 !!!
05-08-2016, 10:13 PM
Bargain, they must've dropped in price since I had to buy some...albeit 7 years ago now!
Ebay or facebook you can probably get a set posted for £20 give or take.
