05-07-2016, 08:50 PM
Hello!
Another problem now that im trying to sort out...
1.The RPM gauge is intermittent on my car. very occasionally it comes on but very juddery.
2. The coolant guague dosnt work.
Work i have done:
I have cleaned the sensor i was led to believe the RPM sensor (connects to the engine by the gearbox mounting, which plugs in round the front on a white 3 pin plug). which has now stopped it working completely.
I have replaced a blue plugged sensor just below the fuel filter housing. however the sensor i replaced it with only had one wire.
The original one had two wires. this has not worked. do i need to have a 2 wire sensor?
Forgot to mention it is the XUD TE 1.9 Phase 1 1996 D Turbo.
Any advice would be great! Thanks Daniel
Work i have done:
