How do you guys remove the T30 bolt under the master cylinder on the spark plug cover?
Short draper bit and a 10mm rachet spanner
I thought they were hex not torx?
I use an allen key there i'm sure, regardless.
Yeah I use an Allen key as well, pretty sure they're Allen unless yours have been changed.
they varied, also some of the cable guides underneath use torx.
Bought a little bit ratchet and cut down a t30 bit 5mm each side.
Sent from my Nexus 4 using Tapatalk
yep ive had both. swapped the torx ones out for the hex ones.
