Another answer needed folks. Been to Peugeot to get top mounts, drop links etc and was only given 18mm as the option for bottom ball joints. But they are 16mm so the question is are the phase 3 1999 ones from my xsi 16 going to work ok? They are 18mm with abs etc. If not I will be needing some replacements if anyone has any for sale cheers
If its 1999 then its 100% 18mm. If you gave them your reg then thats why you only have 18mm available to you mate
(03-05-2016, 08:39 PM)Niall Wrote: [ -> ]If its 1999 then its 100% 18mm. If you gave them your reg then thats why you only have 18mm available to you mate
Cheers mate somethings are never easy with a Peugeot!!
Depends what the previous owners had f*cked about with. I've known of a xsara vts to have 16 and18mm on the front
