Thought I'd ask in the XU section due to track car folk
For an oil cooler is there much difference in terms of durability/installation ease/cooling for using between rubber or braided lines.
Rubber is the cheaper of the two (obviously) but recently tried fitting a turbo oil feed line that had been switched to a braided one and it was a bit of a c*** to fit, enjoyed springing about instead of just fitting nicely.
How many rows would be suggested for a 1.8L N/a engine?
Are the universal kits on ebay any good / a world different to the mocal stuff
Kit's I would avoid as the hoses I find are never right, Buy a take off a Cooler (Setrab) as mocal ones seem to be going thru a bad batch and leaking, then measure up the lines and get some made, getting some swivel joints help instead of fixed fittings but add's to the cost
Cheers for the heads up on the Mocal coolers. I'll look into it a bit more but was just having a gander last night, there are some premade kits available but as expected for that luxury you pay an extra premium
ive got a 13 row one although many say you have to have 16 rows for a 6. If you arent having overheating issues atm id go with the 13.
'6 run pretty hot though so can imagine you'd need more than for a 1.8
In terms of overheating/oil temps I have no idea on what's going on, don't have a oil gauge. Been meaning to read with an obd reader but always forget so 13 has to be better than none
My lines where rubber where fine until the fans rubbed through them so probably going go braided if the the ones I got for free with the cooler are t long enough
So apart from the fan rubbing through they were fine then. Might get the rubber as a first attempt then upgrade to braided down the line if it all works well
Braided look pretty, rubber do exactly the same thing for less money.
all depends on how you like the looks.
What do you need to fit an oil cooler? I see them on eBay dirt cheap! Is it a case of you get what you pay for with a cooler?
Don't forget to mount them on rubber bobbins.
The only issues I've heard of with rubber is as above, poorly routed or secured.
Get proper fittings, no hose clips etc, Rubber is fine if good quality, the braid just goes over this anyway so gives a extra layer of protection. As said kit's are pretty crap really as cooler location is set by the hoses
i use hose from my local eagle plant cheap strong and crimped both ends
Going to be ordering this soon with the thermostat upgrade.
Don't fancy 2 hours of FCS session with overheated oil
http://www.mattlewisracing.co.uk/product.php/1137/0/
In terms of the cooler there's a motamec 13 row on ebay for £38 which looks the same as the mocal
I got a second hand 19 row mocal for 30 on ebay the other day but probably new would be like 100 ish
Matt
You need a sandwich plate lines and cooler and extra oil as the cooler will take some.And bolts/threaded rod to make up a mounting point,if you have slimline fans you mount where the old twins where.
I chose braided lines to help avoid a leak due to chafing. They were not too expensive. I just popped to a hydraulic center and had them knock them up while I waited.
YAh Brought some braided yesterday 31 inches may be abit tight hopefully it's long enough
attachment=27664]
