I will be interested in this too. Want one for when I rebuild the too end of my engine
First one doesn't really go low enough
The second doesn't go high enough
The third goes high enough maybe not quite low enough but probably offered the best bet
As for build quality I wouldn't know as I've never used 2/3 of them but draper I've not had a problem with
to be fair, all i'd be torque'ing up is wheel bolts and injectors, i dont really torque anything else, and both of those are 90/99nm
Would also be interested in this, need to add it to my collection of "what if" tools. :S
Silverline one has a guarantee, only thing between them tbh. All budget makes, so i'm guessing performance will be similar, although i've never heard of hyperion so i'd avoid them personally.
One of the stages of head studs are 20nm? Might be useful
4WayDiablo Wrote:One of the stages of head studs are 20nm? Might be useful
but from what i've found there is no extended torque wrench which goes to 20nm, and max at to at least, 120nm
Really you need 2 torque wrenches, one for less than 30nm and one for the big jobs.
Mine came from Lidl dead cheap and appears to be accurate.
Dum-Dum Wrote:Really you need 2 torque wrenches, one for less than 30nm and one for the big jobs.
this is what i was thinking.
For now, i need the mid range torque settings, 90/99nm settings, then if i ever come to doing head bolts, get another, smaller wrench.
Chris, any advise on the top wrenches? cheapies work just as well as expensive?
As above, big ones are inaccurate on the little stuff and vice versa, so may as well get two if you're going to be using them often.
And you usually get what you pay for, but it's not often you'll be torquing something that'll make a big difference if you're 10% out.
IIRC when PPC did a test on them about a year ago they were all much of a muchness, just the more expensive ones had a little better range. Even the cheapies were within a reasonable degree of accuracy.
Do you have a halfords trade card? Think the mid size one is roughly 40quid with trade.
Maybe a bit more than you want to spend but the do have a lifetime garantee.
I have the biggest one (50 on trade) and it seems well built, easy to use and accurate. Mines for hub nuts and caliper bolts mainly. But thinking of getting a smaller one if I attempt the clutch change on the golf.
Is that a range of 27.1-203? If so I'll get myself one of them
yep, not quite low enough for head bolts, but smaller wrenches would be used anywho.
Sweet may pick myself up one on payday, and get a smaller one for the head bolts
