07-12-2015, 12:05 PM
07-12-2015, 12:11 PM
Yes it will be. It's a push on, push off button. It doesn't stay in when on. You should however hear a relay click when you push it (ignition on/engine running only). Another orange one is the fog light which should stay in when pushed.
07-12-2015, 12:24 PM
The button itself gets brighter when it's on I think?
Fogs are on the stalk on ph3 btw, only other button you'll have is hazards there.
07-12-2015, 12:31 PM
(07-12-2015, 12:11 PM)andywhy Wrote: [ -> ]Yes it will be. It's a push on, push off button. It doesn't stay in when on. You should however hear a relay click when you push it (ignition on/engine running only). Another orange one is the fog light which should stay in when pushed.
Did you just tell me to push off!!??
07-12-2015, 05:09 PM
Tom's right, it should get noticably brighter when pushed to indicate the heater is active. Mine doesn't, as thats something else on mine thats broken.
It also does the heated mirrors iirc.
07-12-2015, 05:45 PM
(07-12-2015, 05:09 PM)WiNgNuTz Wrote: [ -> ]It also does the heated mirrors iirc.
It does indeed.
07-12-2015, 05:48 PM
yeh definitely the rear screen and mirrors. It doesnt click in. Its not very intuitive but it should get very slightly brighter. I doubt the button would ever be a problem.
07-12-2015, 11:11 PM
LoL! A bit late, but I just tried it in the dark. (ooer missus!) It does get brighter as I push it in. (facepalm)(ooer missus!)(facepalm) ROFL! But the brightness goes back to nothing when it's released. On the few cold mornings when I could have done with it, it had no effect, so I stopped using it and decided to ask.
Dammit, I'll have to get on me hands and knees and look at the blimmin fuses. I need to check them as the stereo doesen't work either.
08-12-2015, 01:03 AM
Sounds like the same issue I have. The button SHOULD stay brighter when you let go, to show that the heater is active. I'm not sure which relay/fuse to check tbh, but hopefully someone with better knowledge will be along to solve our woes.
08-12-2015, 09:06 AM
Heated screen is the huge orange relay iirc, top right.
