Full Version: 306 cabrio heater fan issue
Okay here's the issue.
Resistor is gone so only works on setting 4 - That's fine.
However. The fan makes a lot of noise as it would on setting 4, but doesn't actually do anything. It gets hot but you can only feel the heat if you put your hand on the vents, it doesn't actually blow out more than maybe 1cm at a push?
I want to say blocked matrix but I have no cooling issues with it (I'm not sure if an XU7 is the same as a XUD and needs the matrix), any suggestions would be appreciated!
Also, if it is the matrix, how can I clear the blockage?
[attachment=25961]
Just pulled this apart today! ( left side of pic)
Needing anything?
Maybe actually! I need a driver side exterior and interior door handle and the entire rear boot button setup, and one of the little flaps from the roof where it goes up and down (Can't exactly explain what it is)
And more stuff I'm sure haha
The car belongs to my mate( another members dad) so will let you know once if talked to him tomorrow, I know the part your talking about!
Put a list together if you can and let me know as the remain s won't be about long!
