Full Version: Wheel Alignment-2 wheel or 4 wheel??
I am due to get my tracking done this week but im not sure which option to go for?
I know the rear beam is not adjustable-but if 4 wheel alignment was done and the rear beam was out/or damaged would it cause the tracking to be wrong?
Comments Please
is it best to check with the 4 wheel alignment to see if the beam is out/damaged first?
Then if rear alignment is ok-go for 4 wheel alignment?
But if its not ok go for 2 wheel alignment??
4 wheel will check were the rear wheels are pointing (adjustable or not) and 4 wheel will at least leave your steering wheel in the straight ahead position when they have finished adjusting the front wheels. (biased opinion as i only ever use the 4 wheel kit !!!!! )
places that do 2 wheel are the ones you keep going back to every day afterwards to try and straighten the steering wheel !
