Full Version: Fuel/lift pump
Right so pulled up yesterday in the car after driving about most of the day an went back out to the car 15 minutes later and it wouldn't start, now from doing a lot of reading on here and other places I've narrowed it down to the lift/fuel pump, As when I put my ear to it and turn the key round I can't hear any noise cone from it.. I was just wondering because I know it's a common fault, Where's the cheapest/best place to buy a new one, and what exactly is it called, all the things I've seen on EBay etc are £110 and stuff, who else had this problem and what way did yous go about it.. Thanks in advance guys
see similar threads about this on here, test procedure and voltage readings and summut to do with a brown relay by the ecu........
maybe find which terminal on the pump needs 12v and earth and hot wire to prove pump u/s?
this is a dread to me also but has not happened yet thankfully!
As above, do some proper diagnosis first, there's a lot of potential issues on these that could cause the pump to not run. Check the link in my sig for starters.
