So my hdi has been leaking diesel for about 3 months or so at start it wasnt bad only a we tiny bit when I left it over night it would there would be a patch in the morning but I know the injectors have been leaking so thought it was just that and was pretty skint and couldn't afford injectors so left it and the leak got worse but thought injectors were getting worse but it was getting bad everytime I drove the car leaked small drops every 5 or 6 meters I checked the engine and couldn't see we're the leak was coming from but it was dripping diesel of the sump on to the ground so it's obviously leaking onto it, I've bought new injectors (076) and trying to get money together for 2.2 pump. But I powerhoused the engine bay and drove it after it was dry (ish) and pulled in and checked the engine to see where was covered in diesel and it seemed like the fuel filter housing more than the injectors. Probably a pipe going to the fuel filter but revved car whilst looking at the engine and couldn't see. There's 196k on it. Getting a mechanic to check tomorrow and fit the injectors and new fuel filter but anybody had same issues? Or what's your opinions lol
Could be lots of things, leak-off pipes are a prime culprit.
i would say leak off pipes.
Anyone know where to buy new ones or would you have to get them from a breakers? Was told about leak off pipes but forgot all about them and new someone on here could help. Cheers guys
Get some fuel safe pipe from your local motor factors and cut your own new ones, they'll probably have a big reel behind the counter, be miles cheaper than buying pre-cut ones. 1m will do the lot with some left to spare.
Cheers Poodle your never done helping me out lol. All work being done tomorrow will let you know the out come
Happy to help where i can mate, helps when the person on the other end is actually taking in the answers, you have a rarer talent there than you might think lol.
Put the new injectors in the car and serviced it definitely a wee bit quieter and the leak has stopped
next up 2.2 r70 pump in couple weeks
(27-07-2015, 01:30 AM)Deangatt Wrote: [ -> ]Put the new injectors in the car and serviced it definitely a wee bit quieter and the leak has stopped next up 2.2 r70 pump in couple weeks
when you fit this pump to a 2.0 hdi will it need to be told work work with the ECU that you have??
and isn't 196k on a hdi to many miles to map?? or are they ok>?
so if you fitting a 2.2 pump. then your after a stage 2+,
HDI Tuning says you need under 130k on the engine?>
I've got stage 2 map on my hdi with 152k miles
Meh! I stage 1'd my HDi at 180K and sold it at 274K with no issues.
Seen stage 2s with 180k going fine and loads of 150k+ remapped going 100% if mapped right
