09-07-2015, 05:46 PM
So basically lus suddenly wouldnt start the other day. well not very well would eventuality go. so pulled the glow plugs out to replace and not one was working. thought while im here i may as well do the glow plug light mod as i have done in the past that keeps the light on even when it usually goes out.
So it clicks the glow plugs off when your pre heating then starts them up again while running and leaves them on. i know they usually stay on a bit but indefinitely i know they should not. any ideas??
So after fiddling about with relays. The one under the bonnet. Brown one. If I remove it the glow plugs work exactly as they should.
