I'm after a sump to borrow or buy I need it for mock up purposes on the air con pump mountings I believe they are the same. Local the better thanks!
ive got an ally xud one which is the same as the hdi. it has the aircon bit chopped off though. you can have it for cost of postage if you want
That's the bit I needed
I got 1 off a 1.8 xs. Pretty sure that has the air con mounts
£5 be ok? Ill double check i still got it and let you know, Poss be able to find out tomorrow
(13-06-2015, 11:48 AM)Stef205 Wrote: [ -> ]perfect!
I still got you number so hopefully will drop you a text tomorrow
