So while I was over that way for work, I dropped the car into pro-steve to have the stage 1 remap done.
What a difference, noticeable more kick in all gears and on the motorway, 70-90 in 5th for overtaking only of course, was very much improved.
Never had so much fun on Dorset B roads since the S16 I wrote off 13 years ago.
However need to sort injectors as they are a lot louder now so is anyone London based up for doing a swap for me in return for numerous beer tokens?
no point doing the injectors mate, theyu are louder because of the map,
mine sounds like a sowing machine up to 3200rpm then shuts up completely, just get used to it
(20-05-2015, 11:12 PM)toseland Wrote: [ -> ]no point doing the injectors mate, theyu are louder because of the map,
They are definately louder, just concerned they might break?????
They won't break, yet to hear of a set that actually stopped working. I had a set die on me, but that wasn't a mapped car and it was suffering badly for fuel abuse in an earlier life.
Thats that decision made then, turn the stereo up
Or get a bigger exhaust...
(21-05-2015, 08:23 AM)Toms306 Wrote: [ -> ]Or get a bigger exhaust...
For the amount of time it will spend being thrashed I'm happy to live with it if they ain't gonna break, mostly towing trailers in 3rd around London anyway just want more low down pull which has been achieved.
A bigger exhaust would drown out the noise, i think was the point lol.
'slaps Forehead'
Obvious when pointed out, age must be getting to me
Lol, tbf I probably should've said 'louder' rather than bigger.
But yeah it works well...couldn't hear if my GTi6 had any issues over the 3" Magnex...
CBA with a bigger exhaust to be fair, more important bits to do to it and the 306 half trailer I think I have
(22-05-2015, 05:12 PM)Toms306 Wrote: [ -> ]Lol, tbf I probably should've said 'louder' rather than bigger.
with that 3inch magnex on a '6 you could have a rod flailing about through a hole in the block, a flat tyre, and 3 snapped springs and you wouldnt notice it hah!
Why not try a little 2-stroke oil when you next fill up, found it made quite the improvement to mine!
(24-05-2015, 10:39 AM)WiNgNuTz Wrote: [ -> ]Why not try a little 2-stroke oil when you next fill up, found it made quite the improvement to mine!
Been investigating 2 stroke but still on the fence, may just have to give it a go
I had about a third of a tank left, and put about 50-60ml of 2 stroke in, and it's made the injectors considerably quieter.
i might have to try that, mines sounding quite 'sewing machine'y under load, not in a bad way but i think it could be quieter. probably because its the most refined engine/car ive had for a while and it doesnt have any other wierd noises going on to drown it out, not even a tiny exhaust blow.
Yeah that's basically the same as mine was, and now it's much better. Definitely give it a go. Just try not to put too much in, I think cully was using about 200ml to a full tank of derv.
I am going to try some 2 stroke in the 206 with next fuel up...will report back
