07-05-2015, 12:50 PM
As per the thread posted by Matt in here: http://306oc.co.uk/forum/showthread.php?tid=30332
I am following the issues on in my own thread.
Been getting the knocking for some time and saw the above thread and learned a few things from that.
So, last night I took a butchers at the underneath and saw the exhaust sagging low! So the noises may have also been coming from the zorst hitting the heat shield underneath as it was very loose.
When I say very loose, the fucker fell out of the centre pipe when I had a mess with it this morning! So that may have been contributing to the noises I have been hearing. So yeah, went to work on it today and the heavens opened! I got soaked and pissed off very quickly only to get more irritated when the nut sheared off of the clamp
Luckily I had a spare knocking about in the shed and got to work on that. I noticed that there was a lot of 'pull' on the mounts holding the back box so thought I would adjust this accordingly so as to eliminate the 'pull' on the joint. Sorted.
Now moving onto the front end, I have noticed the BJ's are fine, the ARB is loose like a West Midlands whore, drop links are crap, P bush bolts are present and correct but P bushes are shite! So the shopping list is as follows:
P bushes
ARB bushes (maybe some new clamps for these?)
Drop links
Plasters
Valium
Are there any other things I could or should check front end for, that I have missed?
Any help would be greatly appreciated
P bushes
Drop links
Plasters
Valium
