29-04-2015, 12:11 PM
Hi I am after a bit of help with a bit of a strange black smoking issue please.
Not that long ago the car (2001 hdi 172K) just wouldn’t start, after great help on here it was the ecu, so I got one from Pro Steve with one of his stage 1 + maps on.
Fitted it and car started and ran great.
While I had the car on PP2000 working out the above fault it also had a MAF fault logged on there.
So not that long after fitting the new ecu I replaced the MAF with one I got from a mate, it was a genuine item and was only about 2 months old, it made the car go so much better but I did notice that at full throttle under hard acceleration it smoked quite a bit of Black smoke. Which it didn’t do with the old MAF fitted, but if you back off the throttle ever so slightly then it stops smoking.
I have unplugged the new MAF and taken it for a drive and as to be expected there is a slight drop in power nothing major but there is next to no smoke at any time.
I have checked for boost leaks there is a tiny one at the inlet elbow but nothing major but thats been there a while and it never has smoked before only since fitting the new MAF, the boost leak will be sorted out soon. The EGR is blanked unplugged and has been mapped out of the ecu. Has a DE cat and straight through exhaust fitted too.
So could there be something wrong with the new MAF that causes the black smoke, I don’t really want to go and buy another genuine one and it be no different?
Cheers Titch
Cheers Titch
