Pages: 1 2 3 4 5 6 7 8 9 10 11
Hope some of you may find this of interest ?
Please feel free to ask about anything !!!!
I'm also as a few of you who know me am on another 6 Forum & have copied all the updates & Pics over 24months .
Hope some of will enjoy !
Not all are in order of doing ..
Tried to get it to stop much better first 330 Bells & rotors then rear Tarox & Ferodo pads
Then Handle better suspension / steering / all gen bits used where possible !!!!
Then drive better 3j & Redline additive which is amazing.
Next Sachell shift & (Corbeau bucket seats FITTED NOW )....hopefully for 2015 Combe & Pugfest ?
Got my Bucket seat Bases ready !!!!
Throttle bodies / loom / ecu / hopefully next end of 2015
EVEN considering low boost Charger ?
[attachment=22315]
The picture here is with 40mm drop with Spax before any work done & with my 17'' comp mo5 direct fit I still have ....
felt & handled terrible no rear beam or anything was fitted apart from 330mm Bells & Rotors ....
[attachment=22316][attachment=undefined]
[attachment=22317]
[attachment=22321]
[attachment=22322]
[attachment=22323]
[attachment=22324]
[attachment=22325]
[attachment=22326]
[attachment=22327]
[attachment=22328]
[attachment=22329]
[attachment=22330]
[attachment=22331]
[attachment=22332]
[attachment=22333]
[attachment=22334]
[attachment=22335]
[attachment=22336]
[attachment=22337]
[attachment=22338]
[attachment=22339]
[attachment=22340]
[attachment=22341]
[attachment=22342]
[attachment=22343]
[attachment=22344]
[attachment=22345]
[attachment=22346]
[attachment=22347]
[attachment=22348]
[attachment=22349]
Hopefully getting a pair of these before FCS 2015
[attachment=22350]
[attachment=22351]
On back order !!!!
Looking good mate
Do you use it daily? Do you have to modify/cut away the dash for the satchshift?
(22-03-2015, 08:07 PM)7057sam Wrote: [ -> ]Looking good mate
No Sam only used 2-3 times a month Sadly ...
You can leave the Heater in on the new Sachell shift !!
Centre console has to be removed & biggish hole cut in lower bulk head where the main rod & a supplied very large grommit passes through into gearbox ...they look sods to fit with dash in ????
I'm getting my seats before Combe performance day & hopefully Sachell shift before FCS 2015..if next batch gets made on time ?????
(23-03-2015, 06:32 AM)procta Wrote: [ -> ]loved the white alloys!
Thankyou ...
So do I but sadly can't get Dunlops Dzo3s to fit ?
Only bought 1.2s for 16 Dunlops & track work !!!!
They are 17s & were up for sale but trying to keep them & may get them changed to Anthracite ...can't beat direct fit no spacers or spigots ...
May try some top track tyres on them next year unless someone offers £450 ..lol
id have looked into another tyre for those tbh also they are too nice for a track wheel too!
(23-03-2015, 10:14 PM)procta Wrote: [ -> ]id have looked into another tyre for those tbh also they are too nice for a track wheel too!
Tried to look for another Top tyre but 17s arnt cheap / A048Rs would of been good ...they are buggers on the track to keep clean with cerametalic pads though ...lol
I think Anthracite is the best option for them !!!!!
Had a bit of change of heart.... Ordered a pair of Buckets new £300 delivered .
Sat in a ford yesterday with the XL version & they were much more comfortable than stnd width I'm only 34 waist but stnd put me off before I sat in XL .
Seeing as I'm only using them for track days & possibly putting the originals back in they are more than good enough & they have forward & back slide adjustment for diff size drivers which is good as I'm 6'3 & my mechanic m8 is 5'8 who normally drives also .
They should be here Monday ...this means I've saved £400 on them & can spend some money on something else !!![attachment=22393]
Nice build. I love that subframe!
(27-03-2015, 09:14 AM)Eeyore Wrote: [ -> ]Nice build. I love that subframe!
Thank you ...Mei said keep stnd & renew with gen if poss .....Because apart from lower arms everything was renewed with Gen Peougeot parts including 2.4 track rod arms & ends ..it cost a lot ...but Car feels better for it even if my Wallet doesn't .....
The Rear ends been done similar by Jord but 21mm bars fitted & Bilstein Tarmac dampers the better more expensive ones & solid mounts with new rear Calipers / gen back plates & Tarox discs with Ferodo 2500 rear pads....
Also gen new Front anti roll bar inc bushes fitted ....it's the little bits that add up & you then notice !!!
I nearly had them frame bit obviously you got they first
You getting the seats in for combe ??
(29-03-2015, 02:03 PM)7057sam Wrote: [ -> ]I nearly had them frame bit obviously you got they first
Got them Sam ....
100% will be in by Weds night
Passenger side fitted had to modify Side mounts & take forward & rear slider mech off as for me being 6'3 it's to high & my heads 1inch from the headlining without Track helmet ...
Drivers side needs Stainless cutting & welding adjustment & modifying quite heavy for the seat to be low enough & comfortable for me ....
New ....temp track seats fitted ...sadly couldn't fit supplied seat slider mech as it lifted the seat up 1.5 inchs & being 6'3 with my track helmet on it touches the headlining ...don't want to weld any permanent bars in cause I can refit the original seat back in after track days without much hassle ...NOW what to do with the seat belts ?????
And some countersunk 8mm bolts are needed for the back of base of seat frames allowing the seat to tilt back 20mm more without the bolts hitting the underside of the corners of each side of each seat ....should be perfect then ?
[attachment=22444]
[attachment=22445]
Base fits well & love Stainless steel box section & top righthand corner of picture of bases have built in seatbelt fixing
[attachment=22447]
Nice seats. Look like something i have sitting waiting to go in mine haha. Looking good think i might fit mine this week after seeing these in yours
These are XL & are so comfortable ...big Thank you for advice !
Happy to help as always mate
Thank you Eddy & please get yourself to Combe either next month spring action day or FCS
Just fitted some lockable Aero Catches just to be on the safe side for Combe ![attachment=22628]
Fancy a nice fibreglass bonnet for that fella?
Nice catches,I hated doing mine but actually came out ok
Did you paint around the cuts underneath the bonnet to prevent it from rusting?
I never paint around the cuts when i fit them and there always fine
need to get some for the rallye
I usually fit mine this way
Yeah rallye's went at slight angle,dunno if I could do it to the astor though
[attachment=22634]
This might help change your mind sam
(12-04-2015, 11:38 AM)7057sam Wrote: [ -> ]Nice catches,I hated doing mine but actually came out ok
Yes 100% did Sam ...the stuff we use in work is used for steel boat anti corrosion like Red lead but legal !!!!
(12-04-2015, 07:40 PM)eddy_gti6 Wrote: [ -> ]This might help change your mind sam
Looks Mean Eddy
(11-04-2015, 06:39 PM)Piggy Wrote: [ -> ]Fancy a nice fibreglass bonnet for that fella?
Would like a painted Carbon one Piggy
[attachment=22658]
Got a 50mm steering wheel spacer fitted as no dish on the Momo & now the bucket seats are in it was a little bit of stretched arm !
Plus cheaper than selling a £140 new wheel ...
Also keeping the lap belts & this little Gadget for tensioning the lower belt & keeping you pushed into the seat on track days is a god send
The Old Stig / Ben Collins uses one SO must be good OR is he paid ????
[attachment=22659]
[attachment=22660]
New 2.5 Magnex PS exhaust bought 2nd hand ...
It was far to good a price to turn down ..
Running AT mo a Original Peugeot Cat & 2"stainless cat back two box system runs at 83db at Combe testing !!
Bought a full stainless steel 2nd hand Peugeot sport looks big (2.5 from 1/2 way down decat right through to the end of the tailpipe ) complete system with two silencers & has decat pipe & I got it for a great price & I'm thinking about fitting it to my stnd engine 6 ????
Problem is I'm being told I will may lose some mid range but gain at top end ?
The 306 maxi car it came off of was bodies & cammed & made 98db
[attachment=22661]
Decat for Combe only
[attachment=22674]
[attachment=22675]
Fitting the exhaust will free up the gas flow and sound a hell of a lot better ?
Yeah I run a decat and Magnex and it's fine at combe,only problem is that I keep breaking it
Catch tank looks good
(15-04-2015, 10:13 PM)eddy_gti6 Wrote: [ -> ]Fitting the exhaust will free up the gas flow and sound a hell of a lot better ?
Hope so Eddy looks like Sachell shift won't be here before Combe next week ?
Got new Mot today
(16-04-2015, 12:57 AM)7057sam Wrote: [ -> ]Yeah I run a decat and Magnex and it's fine at combe,only problem is that I keep breaking it
You keep breaking what Sam ? The Exhaust ?
