10-03-2015, 08:59 PM
owned this car for 2 year's now and some of you may have seen it at FCS or Pugfest, Decided to break it rather then loose a fortune in money payed for parts.
Alot of parts are still shiney new, Car has seen hardly any use in the past 6 months
All parts are available, Evan the bare shell to anyone intrested, just needs some attention so front jack points
Shell has 154k, Engine has 103k, Fitted after hydrolocking the last one during last years floods.
Evreything can be posted, Obviously engine will be palleted and axle with heavy courior etc, Ive included delivered prices with some but most of them better of pm'ing me as prices varie on locations!
The specs and usuals are as follows..
Engine (103k, Cambelt & waterpump fitted 99k) Will be top & bottum end only with standard cams £300 - SOLD
Piper 270 Fast roads Done 4000 miles ( Currently fitted to engine at 99k) £200 - AVAILABLE AGAIN
Maniflow 4 2 1 MILD manifold (This is the offroad use one, Bigger better & Noisier) BRAND NEW - £400 - SOLD
Gearbox 103k - £80
3.5 Bar genuine FPR - £30
Rallye AUX set up (Brand new, done 100 miles) - £70 - SOLD
BMC Carbon enclosed CDA Airfilter - SOLD
Inlet Manifold with injectors & Throttle body - £80
Baker BM Engine Mounts & Lower fork bush New, Not evan seen 200 miles - £100
Baker BM Brand new never used Gearbox mount - £30
Magnex 3" 2.5 S/S Exhaust Catback System, Has had the welding done so all good £120 - SOLD
B&M Short Shift (Sllide over gearshaft shaft type) £20 Delivered - SOLD
Nissens Rad VGC - £50
Rose Jointed Gear Linkages near new £25 delivered to Uk main - PROV SOLD
Unlocked ph2 gti 6 Ecu - £60
Engine loom - 30
TA Technix Coilovers, These are my 2nd set always run at 40mm so not bad - SOLD
21mm Torsion Bars, One end bolt needs attention - £80
Recently rebuilt rear axle using BRAND NEW Genuine Pug rebuild kits (Expensive) Standard 20mm bar - £300 SOLD
Baker BM Solid Rear Mounts - £100 - SOLD
Bilstein B6/b8 Rear Dampers - £70
Near New Aftermarket Wishbones - £40
Team Dynamic Pro 1.2's 16x7 Black Alloys in Reasonable
Condition,Tyres are budget, Fronts 3mm rear 5mm £250 - PROV SOLD
Near new pair of 12mm billet steel hubcentric spacers - £30
Near new pair of 10mm billet steel hubcentric spacers - £25
Gti 6 Calipers with Green stuff front pads, Pads have alot of life but discs worn out - £50
18mm Hubs, Not long fitted these - £40 pair, 20 per side
23mm Master Cylinder - £25 Delivered
Drive Shafts - £35 pair or £20 long, £15 short
PH1 GTI 6 Alacantra Seats, Bolsters are fine no rips, One small burn in center of drivers seat, P/s has small tear front underneath - £120
Rallye Door cards in VGC - £50 PROV SOLD
JVC Stereo In full working order - £40
Rallye Manual Windows - £30 per side (P/s missing handle) -SOLD
Team Heko Tinted Wind Deflectors in VGC - £25
Rallye Blanks in VGC - £15
Ph3 Front Splitter - £25
Ph3 Spoiler - £20
Luke Yellow Tow Strap (Still in wrapper unfitted) £10
Bianca Bonnet, No dents but some stone chips - £40
Bianca Rear Bumper, Odd mark here n there but otherwise good - £30
Bianca PH2 Skirts, No cracks but maybe the odd mark - £30
Bianca Ph3 Rubstrips, Some peel and marks - £30 - SOLD
Bianca Bootlid PH3 - Needs a buff, Good condition though - £30 -SOLD
Bianca Door Shells £30 each, P/s In good condition but drivers side has peel and minor dimples - P/S SOLD
Black Mask Headlights, DIY done long time ago to a decent standard. Dont fog up etc - £45 - SOLD
2x Bianca Grills 1 some chips £10, Other in good condition £15
Bianca Wings, £40 pair or £20 each. Maybe minor marks but otherwise good - P/S SOLD
Bear with me on the photos, Its 9 o clock at night lol. I will add some of the car itself though. Please bear in mind the photos of it on nimrods are old, Its been sat at 40mm on black TD's for some time now. Car is currently together still, Will be split up within the next 10 days hopefully most sells by then so im not getting greif from the wife for using the living room as storage.
Thanks
Gearbox 103k - £80
Engine loom - 30
Ph3 Spoiler - £20
Thanks
