08-03-2015, 06:25 AM
08-03-2015, 07:31 AM
there are two types of clones
early set take a flat seated bolt that has no tapered shoulder
later clones have a counter bore in the bolt holes which accept the later bolts that have a shoulder which secures the steel spare wheel
![[Image: c252475f-b5a1-415c-bfdc-b11b5d56087e.jpg]](http://img.photobucket.com/albums/v159/cully/pug306/c252475f-b5a1-415c-bfdc-b11b5d56087e.jpg)
08-03-2015, 07:51 AM
ive got a set of the later ones inc locking bolts if you need them.
08-03-2015, 04:53 PM
(08-03-2015, 07:51 AM)welshpug Wrote: [ -> ]ive got a set of the later ones inc locking bolts if you need them.
Which 1s are the later 1s mate?
08-03-2015, 04:56 PM
08-03-2015, 05:57 PM
(08-03-2015, 04:56 PM)cully Wrote: [ -> ](08-03-2015, 04:53 PM)SACHAx Wrote: [ -> ](08-03-2015, 07:51 AM)welshpug Wrote: [ -> ]ive got a set of the later ones inc locking bolts if you need them.
later ones are the bolt on the left in the picture
I think it's the early set I need then mate, as the standard 1s off the meridian wheels I believe look like that then?
08-03-2015, 06:22 PM
I thought it was the GTI ones that had just the flat seated bolts as the spare was an alloy, whereas the other type was off the meridians etc, and ran a steel spare hence the taper?
08-03-2015, 09:17 PM
(08-03-2015, 06:22 PM)Jonny81191 Wrote: [ -> ]I thought it was the GTI ones that had just the flat seated bolts as the spare was an alloy, whereas the other type was off the meridians etc, and ran a steel spare hence the taper?
Yea I think it's the GTI bolts I need without the taper
09-03-2015, 10:44 PM
You have a pm
09-03-2015, 10:51 PM
(09-03-2015, 10:44 PM)Dale Wrote: [ -> ]You have a pm
They won't be able to reply to it, as they don't have enough posts. This seems a bit like a "Wanted" thread to me, so should be in the Wanted section, but then the OP can't post in there either due to lack of posts. Naughty naughty.
09-03-2015, 10:54 PM
(09-03-2015, 10:51 PM)WiNgNuTz Wrote: [ -> ](09-03-2015, 10:44 PM)Dale Wrote: [ -> ]You have a pm
Ooooo I see they best get posting in that caseĀ
