what is the capacity of the windscreen washer resevoir please..........1 1/2 lites??
the washers on our 306 seem to stop working and need 1 1/2 litres to top up to the top, then they work again.......all help greatly appreciated.
Bit more I thought but not much, the pump enters at the bottom so if there's water if should pull it up, unless you've gotten some shizer in there like a leaf or whatever
thanks for that.....if it aint broke etc........but will shine a torch in there and have a look see......must be more restrained with the washers.......may do a mod so the washers work then after a short delay the wipers kick in..........tis the other way round at the moment........wipers start then washers start....so screen dry with wipers working.............till the water gets pumped to the screen.....
Check the pipes aren't split and fit Xsara mist jets like we all do, fine spray covers 10x better so lasts longer
