Afternoon all.
Can anybody tell me what the relay mounted on the back of the ecu / battery housing is for?
The mounting on mine is broken after a slight mistake
and i might have to replace it if i cant glue it back together.
Cheers
It's for the fuel pump, you really don't want water getting in there so make sure its sealed well if you glue it.
Fuel pump and ecu power distribution. They all break. Either tape it up and seal it up or get a new one. IIRC a new one is about £35 from pug.
Thanks guys i have it setting as we speak ill see what its like in the morning. Hopefully it will be ok.
Last thing you want is water to get in there. It can do all sorts of weird and wonderful things to how the car runs (if at all!)
My old one on my 1.8, i glued the broken plastic back and then wrapped it up in lots of insulating tape. Did the job just fine but i broke mine so i know it had no water getting in there before. If theres a chance water could of been getting in before, i would replace it anyway
So glue set well and car is running once again. I know there is no water in there. I removed it and put it in a safe place with some other bits went to fit it again and promptly dropped it and trod on it..... D'OH!!!!!!
