Will I need a new crush washer for the gearbox plugs when I change the oil?
CheersĀ
Yes. They do often leak when re-used....as I always forget to replace them.
Haha cheers
was just checking before I dived in head first lol. I suppose to drive to go and get some will warm my gearbox oil up a bit so it drains nicer
cheers mate
Are they the same as the ones on the sump??
Got a feeling mine was different, will have a look in a mo.
There are 2 different washers. 1 is a bit bigger and used on the TU sump plugs. I think the 1s for the gearbox are the same as the sump plug though on a hdi.
If anyone ever needs washers i got plenty in stock at work i can post out for a small fee
You're both dead right, i'll stfu.
I changed the gearbox oil the other day the sump plug for the sump is too small for the gearbox drain plug
