My hdi has felt underpowered for awhile now,
Have changed MAF
Serviced, oil, filter and diesel filter
Egr blanked at inlet
Boosting at 13psi until around 3500rpm drops to around 10/11
Injectors tapping worse and worse.
Would injectors cause the power loss?
Would a leak off test be any use?
Want to get it fixed before i go stage1
Wait, its standard? No wonder it feels slow!
Has it always felt slow or suddenly became slow?
Could of just got used to the power therefore giving you the feeling of it being slow/slower
release the Minion he's holding you back !
(31-01-2015, 08:56 PM)Toms306 Wrote: [ -> ]Wait, its standard? No wonder it feels slow!
Haha, its going stage1 when i have it sorted,
Had more power before, power came back one day when boost gauge pipe came off inlet,
(31-01-2015, 09:24 PM)shervo Wrote: [ -> ]Has it always felt slow or suddenly became slow?
Became slow few months back, thought that myself but power came back for a minute,
(31-01-2015, 09:26 PM)cully Wrote: [ -> ]release the Minion he's holding you back !
NEVER! :-D need to get a bigger one if anything :-)
Did you sort this?
I don't understand why the power would come back when the pipe to the boost gauge came off, that should have made it worse?
My hatchback back is feeling really slow at the moment.
(06-02-2015, 02:03 PM)DeeTurbo Wrote: [ -> ]Did you sort this?
i changed the injectors last night, seems better as mine were tapping like crazy.
im just going to remap it now as i cant seem to find whats making it slow
it did 30-60 in 8 seconds, dont know if thats good or not
Have you checked to see if any of the brakes are dragging?
(06-02-2015, 02:21 PM)DeeTurbo Wrote: [ -> ]Have you checked to see if any of the brakes are dragging?
handbrake was abit as i tightened it abit much but loosened it off and still same,
going to try get it on peugeot planet soon
Is the TPS turning all the way when you press the throttle? Is there a boost leak at the turbo outlet?
(06-02-2015, 07:04 PM)pro_steve Wrote: [ -> ]Is the TPS turning all the way when you press the throttle? Is there a boost leak at the turbo outlet?
i adjusted the throttle cable so thats fine,
there seems to be a fair bit of oil around the turbo pipes, but oil level not dropping on dipstick.
