How is this possible? Do these remap well or something? Was in 3rd at 40 at peak boost and went to nail it and he kept up with me, and my car is running pretty well at the moment
Somethings wrong with yours imo.
Those 1.3s are ok, but pretty flat!
Thats what I thought, no binding rear brakes as I had a new calliper put on the rear recently, and its been going really well for a Stage 1 ever since :/
Bad driver blames his tools.
Those 1.3s used to be 90bhp, are you sure its only 75 now?
Never knew they did a 90 version Tom??
Granny shifting not double clutching like you should?
Whats to say he didnt have a remap on it? In all fairness they weigh f*ck all and i bet a remap would have it on the right side of 100bhp?
It was a 75bhp one, guess its been mapped to keep up with mine as theres nothing really wrong with mine, says 73bhp one on mycarcheck, strange and annoying, was from 40-70 in 3rd so didnt need to change any gears
Are you sure it wasnt an evo? I know an evo wont beat a gti6... but it might just have the edge on a stage 1 hdi...
Don't see why its annoying tbh...there are lots of cars faster than a S1 HDi lol!
Looks like the 75s map up to about 95bhp, its a smaller car, and its not lugging around an extra 0.7 litres of engine unnecessarily, much better power to weight... Probably has a VNT turbo for more efficient boost and torque curve as well...
Theres 30 bhp difference and a chunk less torque though Tom, they may be slightly lighter but not anywhere near enough to make up the difference
power to ratio I think with this one, plus new engine tech too.
Power to weight really isn't the only factor. Power isn't really relevant for this, its torque that matters here, and your torque hasn't hit max until about 3k iirc...in the Corsa it'll hit max torque well before 2k so will obviously pull away while you're still waiting for boost! VNTs make diesels so much more driveable. Plus, how much more torque on a S1 HDi? Probably not much in it...
Who cares? He was driving a wanky Corsa and you have a 306. Ergo, you won.
Sure I saw a stage 1 dyno which showed peak torque at 2.2k revs, although power and torque to weight and what you said Tom are the main factors, I suppose my HDI cost me £500 vs nearer 15K for a LE Corsa
(25-01-2015, 05:45 PM)Toms306 Wrote: [ -> ]Power to weight really isn't the only factor. Power isn't really relevant for this, its torque that matters here, and your torque hasn't hit max until about 3k iirc...in the Corsa it'll hit max torque well before 2k so will obviously pull away while you're still waiting for boost! VNTs make diesels so much more driveable. Plus, how much more torque on a S1 HDi? Probably not much in it...
that's why I said new engine tech, it might have the same amount of torque as the HDI stage 1, also gearbox ratio plays a good part too.
Oh wait, was it a limited edition Corsa? They iz well fast mate trust.
If you're worried about beating other cars, get the Rallye OTR.
Though then you'd probably moan about getting beaten by a 1.6 Corsa with a silly VXR badge...
(25-01-2015, 05:50 PM)procta Wrote: [ -> ] (25-01-2015, 05:45 PM)Toms306 Wrote: [ -> ]Power to weight really isn't the only factor. Power isn't really relevant for this, its torque that matters here, and your torque hasn't hit max until about 3k iirc...in the Corsa it'll hit max torque well before 2k so will obviously pull away while you're still waiting for boost! VNTs make diesels so much more driveable. Plus, how much more torque on a S1 HDi? Probably not much in it...
Yeah I was replying to Matt but you got in first lol.
Newer engine tech is something that does interest me tbh, still finding out little things about the DV6 that make it lighter or more efficient lol.
(25-01-2015, 05:48 PM)MY95 Wrote: [ -> ]Sure I saw a stage 1 dyno which showed peak torque at 2.2k revs, although power and torque to weight and what you said Tom are the main factors, I suppose my HDI cost me £500 vs nearer 15K for a LE Corsa
I think he would have got a bit of a surprise, that you still had the run on him, due to the fact the age of ours cars, Old vs New.
I bet he would have been thinking he would have had the run on you really.
tom I think its all ecu trickery now,
(25-01-2015, 05:56 PM)procta Wrote: [ -> ][quote pid='509106' dateline='1422208135']
[/quote]
Nah, theres loads of physical things as well, some really simple!
Edit - Hmm, this WYSIWYG quote system is difficult to cut!
(25-01-2015, 06:15 PM)Toms306 Wrote: [ -> ] (25-01-2015, 05:56 PM)procta Wrote: [ -> ][quote pid='509106' dateline='1422208135']
[/quote]
be that aswell, most of the new engines and cars all run turbos now anyway if I am right.
[/quote]
You can turn that off in your user CP
Just accept it, your old french tin got done by a vauxhall. Christ id be so embarrassed about that
(25-01-2015, 06:17 PM)procta Wrote: [ -> ]be that aswell, most of the new engines and cars all run turbos now anyway if I am right.
Yep, save weight and retain performance by keeping the engine small and fitting a new tech turbo!
(25-01-2015, 06:31 PM)Niall Wrote: [ -> ]You can turn that off in your user CP
Done!
(25-01-2015, 06:31 PM)Niall Wrote: [ -> ] (25-01-2015, 06:15 PM)Toms306 Wrote: [ -> ] (25-01-2015, 05:56 PM)procta Wrote: [ -> ][quote pid='509106' dateline='1422208135']
[/quote]
or you could say corsa diesel.
Those little Corsa's are actually rather nice. Well screwed together, nice airy cabin, comfortable and filled with gadgets. They handle well (albeit they have the same featherweight wanky steering yyou get on all modern cars) and the brakes are fantastic too (if a little over-assisted).
The main letdown in all of them (for me) has been the engine and gearbox. Namely, the 1.2. This engine is a dinosaur and I'm surprised something so modern could be fitted with something so shite. But hey, it must be economical right? Wrong! f*cking mid-30s MPG!
So, I can imagine that given the right engine (ie.VXR) they are probably fantastic.
They all look shit from the outside however especially those with the "trying really hard bodykit and wel yooneek black rimz"
How much are we talking about being beaten by? Actually you only said kept up with. one of my old cabbys would "keep up with" foobys GTi6. It certainly wasn't faster but real world the 30bhp makes very little difference, remember you need 33% more power to be 10% faster.
There is potential that his gear ratios might of been better for that specific bout of acceleration, he might of done a gear change, he could have a remap on it, his car is potentially 50kg lighter and most corsa owners are about 7 stone wet through so could add another 50kg to the weight difference and all that shit.
If it helps, when my HDi was stage 1, it had no issue keeping ahead of the 1.7 130 CDTi.. (wasn't by much, but pulled slightly)
