Full Version: PH2 AUX setup / A/C pump
I need a A/C pump and a PH2 AUX setup.
No so worried about teh auto tensioner, but need all brackets and also if the PH1 PAS pump doesn't fit I'll need the PH2 pump please.
A/C compressor ideally sealed from the elements and in full working order not long removed, else waiting to be removed from the car and still sealed.
Ideally also would be the fittings from it to the high and low pressure lines which can happily be cut after a short length if it's ally.
Appreciate the vagueness of the request.
So ideally someone around Warrington/Liverpool/Manchester area so I can come take a look and remove ??
