16-12-2014, 09:19 PM
17-12-2014, 04:52 AM
Have you got the leads on the right way on the relay?
One is from the battery the other goes to the plugs
17-12-2014, 10:30 AM
(17-12-2014, 04:52 AM)Paul_13 Wrote: [ -> ]Have you got the leads on the right way on the relay?The O-ring connections will only go on one certain pole as the O rings are different sizes, Black is my current bosch relay, green one is the new nagares relay
Brown wire and a White wire both tight and have removed any corrosion
Symptoms; no light on dash, no click from relay, no power to glow plugs so no heat
[img][/img]
[img][/img]
17-12-2014, 10:54 AM
The bigger terminal of the 2 should have the feed from the battery
