The rear wiper motor just makes a noise now and does nothing. It would sometimes work then not work now nothing. So I think its time to de wiper rear back motor.
I can see whats holding the motor in place. But whats the best way to get the spindel spine out of the glass?
Also what the best bung to use one that doesn't leak or come out?
306 hdi
thanks
Welshy_Pete Wrote:The rear wiper motor just makes a noise now and does nothing. It would sometimes work then not work now nothing. So I think its time to de wiper rear back motor.
306 hdi
thanks
Once you have the wiper arm and assorted washers off, you should be able to undo the two bolts holding the motor in place, and pull the spline through the hole. Normally comes away pretty easily.
<!-- l --><a class="postlink-local" href="http://www.306oc.co.uk/forum/viewtopic.php?f=31&t=208" onclick="window.open(this.href);return false;">viewtopic.php?f=31&t=208</a><!-- l -->
Should be all in there
i used a gutter bolt, washer and some sealer to keep mine water tight..
I have just de-wipered mine.. Brilliant modd!! I also stuck a bolt in the pipe for the rear washer just to avoid any accidents
Anyone got a rear wiper bolt cover spare? Mine is missing me and it does my head in
Cheers
