Full Version: Phantom Connector
While getting my inlet manifold back on I dropped a bolt down the side of the block. I found it resting on this connector. (grey one between starter and bracket)
What on earth is it? Huh
Nothing from my loom matches it and I remember changing it from the old blown block onto this replacement one.
Annoyingly this is all I need to sort before I pop the manifold on and drop the engine in! aaaagh
[Image: sa3OwT0l.jpg]
I'll do a build thread eventually lol
Oil pressure switch.
there's often two switches fitted, so you wont have a plug for that one.
Is that the one on the same loom as the wire that goes to the idle control valve? I found a similar one while changing mine and can't figure out where it goes.
