How many things does the handbrake light represent? Mines stuck on and didnt know if its just a simple faulty sensor or chaffed wire
Is it just the handbrake light on? If it comes on with stop light itll be low fluid warning, if its on its own itll most prob be the little switch under the console
Sweet thats all I thought it was, just plays my turbo timer up as the cut off is wired into the handbrake for safety
Could be brake fluid low!
Na brake fluids sweet. Must be the sensor as what other reason would my turbo timer play up for? It's t'ed into the handbrake sensor wire
Hi guys, I have the same problem, what and where is the switch under the console?? My brake fluid is topped up and it gets a bit duller when the handbrake goes off.
Any ideas?
Thanks Paul.
Under the handbrake itself
Ok I'll check, ta.
