(26-11-2013, 08:37 AM)tropical peugeot Wrote: [ -> ] (13-04-2012, 08:00 PM)cully Wrote: [ -> ]yes the build code is a roling date code! and build factory code
system was introduced in 1976 where they started with 0001 it has been increased by 1 each day since
Hi
I am new to this forum. I am trying to obtain the DAM for my Peugeot 306 and using the Excel spreadsheet. I got the code from the door sticker and it is as follows:
9631383480
I am not sure which numbers to use to decode the date of manufacture though. Can anyone assist.
Chassis is: VF 37AK5A232398998
THANKS
the number you quoted is the wrong one
your info is
Vehicle characteristics
Vehicle family 306 (RESTYLING)
Build code 7834
Warranty Start Date 01/01/1990
General information
PRODUCT TYPE CAR
COMMERCIAL MARQUE/COMPONENT TYPE PEUGEOT
VEHICLE FAMILY 306 (RESTYLING)
SILHOUETTE 5 DOOR SALOON
TRIM LEVEL SELECTION PACK
ENGINE CARBURETTOR TU3-2
TRANSMISSION BVM5
PAINT TYPE NON-METALLIC PAINT
INTERIOR TRIM TYPE NAPOLI VELVET "EH"
UPHOLSTERY COLOUR "FY"
GEARBOX (CHARACTERISTICS) UP-RATED BVM/MA (A/B)
ENGINE (TYPE) TU/TUD
OTHER BADGE, " MISC. " WITHOUT FULLER BADGE
BADGE XR
STEERING UNVARIABLE POWER STEERING
SPEEDOMETER DRIVE TACHO TORQUE 21X18
Fuel supply-Engine
FUEL FILLER CAP FUEL CAP WITHOUT LOCK
DIESEL FILTER WATER DETECTOR WITHOUT DIESEL FILTER WATER DETECTOR
CYLINDER BLOCK (MATERIAL) CRANKCASE ALUMINIUM
FUEL PETROL (87/98)
EMISSIONS STANDARD (ENGINE) 15-04 DEPOLL (ENGINE)
PRE-FILTER ASSEMBLY WITH PRE-FILTER
CATALYTIC CONVERTER WITHOUT CATALYST
OIL COOLER WITHOUT OIL-WATER DISTR CHAMB
ENGINE TEMP. NOZZLE ENGINE WATER TEMPERATURE BOX
CRANKCASE GAS CIRCUIT HEATING W/O HEATER CASING GAS CIRCUIT
FUEL SUPPLY CUTOFF NO FUEL FEED CUT-OFF
POWER VARIATION (ENGINE) STANDARD POWER
REGULATION 70/221 (FUEL LEAKS) WITH ANTI-RETURN VALVE
RHEOSTAT NO RHEOSTAT
FAN 1 FAN , 2 RATES
FUEL VAPOUR RETRIEVAL WITHOUT PETROL VAPOUR RECUPERATION
INJECTION ASSOCIATED VARIANT W/O INJECTION VARIANT
Gearbox Transmission
TRANSMISSION BVM5
FINAL DRIVE RATIO REAR AXLE HYPOID GEARSET 13 X 59
WHEEL STYLE BLACK OPTIMIZED WHEEL
CLUTCH CABLE CLUTCH TAKING UP OF PLAY
AIR CHAMBER WITHOUT INNER TUBE
GEARBOX SAFETY LOCK W/O G/BOX SECURITY LOCKING
DIFFERENTIAL (GEARBOX) STD GEARBOX DIFF
TYRE (SIZE, TYPE) 185X65X14 H TYRES
WHEELS FITTED 5,5" RIM ROAD WHEELS
WHEEL (TYPE) STEEL WHEELS
GEARBOX TYPE MA
Suspension-Steering-Brakes
ABS W/O ABS BRAKES
REAR ANTI-ROLL BAR REAR ANTI-ROLL BAR DIAM 20
ANTI-THEFT DEVICE STANDARD ANTI-THEFT
FRONT ANTI-ROLL BAR FRONT ANTI-ROLL BAR DIAM 18
TRACTION CONTROL WITHOUT ANTISLIPPING
SERVICE BRAKE WITH INTEGRATED COMPENSATOR
BRAKE TYPE NON-VENTILATED FRONT DISCS/REAR DRUMS
SUSPENSION FR/RR HEAVY DUTY SUSPENSION
BRAKE ASSOCIATED VARIANT WITHOUT ABS
Body fittings
TOWBAR WITHOUT TOWBAR
HORNS HORN STANDARD
AERIAL LONG ROOF AERIAL
WIPER ARM FRONT BLADE WITHOUT DEFLECTOR
HOOD WITHOUT HOOD
REAR SPOILER ASSEMBLY WITHOUT REAR SPOILER
SIDE MOULDINGS (DIMENSION) LATERAL PROTECTORS WIDTH = 40
WHEEL EMBELLISHER (STYLE) FUGUE STYLE 5 HOLES 14 INCHES
ADDITIONAL SHIELD (UNDER ENGINE) ENGINE UNDERSHELDING
HARD TOP WITHOUT HARD-TOP
EXHAUST TAILPIPE TRIM W/O EXHAUST OUTLET EMBELLISHER
ENGINE BAY SOUNDPROOFING WITHOUT SOUND-PROOFING
WINDSCREEN WIPER FRONT WIPER BLADE W/O RAIN SENSOR
REAR SCREEN WIPER REAR SCREEN WIPER
HEADLAMP WIPER W/O HEADLAMP WIPER
FRONT PANEL BLANK BUMPER GRILLE NOT CLOSED
BUMPER UPPER PART DYED - LOWER PART BODY COLOUR
LUGGAGE RACK WITHOUT ROOF BARS
FRONT FOGLAMP NO FRONT FOG LIGHTS
SPECIAL HEADLAMP (DOUBLE OPTIC) SINGLE OPTIC LAMPS
EXTERIOR REAR VIEW MIRROR (DRIVER SIDE) NON HEATED EXT DRIV RRVIEW MIRROR MAN CNTRL
EXTERIOR REAR VIEW MIRROR (PASSENGER SIDE) NON HEATED/MANUAL CNTRL PASSENGER OUTER REAR MIRRO
SPARE WHEEL STEEL WHEEL + STANDARD TYRE
EXTERIOR ACCESSORIES UNCOLOURED DOOR HANDLES + DOOR MIRRORS
SPARE WHEEL MOUNTING STANDARD SPARE-WHEEL CARRIER
REAR SCREEN WASH REAR SCREEN WASH
SUN ROOF FIXED ROOF
HOOD COLOUR WITHOUT HOOD
REAR WINDOW (TYPE) REAR GLASS HEATED
GLASS (APPEARANCE) TINTED
REAR QUARTER WINDOW (TYPE) WITHOUT REAR QUARTER GLASS
Interior fittings
SIDE ARMREST (TYPE) LATERAL ARMREST INJECTED FR/RR
ANTI-THEFT ALARM WITHOUT THEFT PROTECTION ALARM
REAR HEAD RESTRAINT WITHOUT REAR HEADREST
FRONT HEAD RESTRAINT JOINTED FRONT HEADREST
REAR SEAT SEPARATE FOLD BACK BENCH SEAT
REAR SEAT ARMREST WITHOUT REAR ARMREST
LOAD FLOOR MOULDING WITHOUT LOAD FLOOR STRIP
LUGGAGE COVER WITH LUGGAGE COVER
REAR SEATBELT RR RETRACT BELT+STATIC LAP
FRONT SEATBELT INERTIA REEL STRAP LOCK WITHOUT ALARM
CLIMATE (AMBIENT TEMP) HOT COUNTRIES
SPEED GRADUATIONS GRADUATION KMS/H
GRAB HANDLES FR + RR HANDLES WITH HOOKS
TACHOMETER REV COUNTER WITH NEEDLE
CONSOLE LONG CONSOLE WITH AIR DUCT
DRIVING POSITION RIGHT HAND DRIVE
LOAD SPACE LIGHTING WITHOUT ARRANGING LIGHTING
BOOT AND LOAD SPACE LIGHTING AUTO BOOT LIGHT OR LOAD VOL SWITCH
DASHBOARD EQUIPMENT THERMOSLEEVED DASHBOARD + METAL PANEL
MISC. INT. LAMPS MAP READING LAMP
INSTRUMENT PANEL (CHARACTERISTICS) 4 DIALS WITH LUMINOUS NEEDLES
TACHOMETER (SIGNAL CONNECTION) REV COUNTER COIL
CHILD SEAT ANCHORING POINTS WITHOUT CHILD SEAT MOUNTING
LOUDSPEAKER 4 LD/SP DUALCONE (2/FR DOORS+2 REAR)
RADIO CONTROLS WITHOUT REMOTE RADIO CONTROL
SCREENING (BLIND, SIDE SUNBLIND, SUNROOF) WITHOUT REAR BLIND
FRONT PASSENGER SEAT HEIGHT CONTROL WITHOUT FRONT PASSENGER SEAT HEIGHT ADJUSTMENT
DRIVER SEAT CONTROL DRIVERS FRT SEAT MANUAL CNTROL
FRONT PASSENGER SEAT CONTROL PASSENGER FRT SEAT MANUAL CNTR
DRIVER SEAT ADJUSTMENT RECLINING DRIVER’S SEAT BACK
FRONT PASSENGER SEAT ADJUSTMENT PASSENGER TILTING BACK
ROOF CONSOLE LONG ROOF CONSOLE
CHOKE CONTROL MANUAL CHOKE FLAP CONTROL
EXTERIOR TEMP. INDICATOR WITHOUT EXT TEMP INDICATOR
COMPACT DISC WITHOUT COMPACT DISC
REAR WINDOW LIFT MAN CTRL REAR WINDOW LIFTER
DRIVER’S WINDOW LIFT ELECTR CONTROL DRIVERS FRONT WINDOW LIFTER
PASSENGER’S WINDOW LIFT ELEC CNTRL PASS FRONT WINDOW LIFTER
CLOCK NUMERIC CLOCK
COURTESY MIRROR DRIVER+PASSENGER WITHOUT LIGHTING
OIL GAUGE W/O OIL LEVEL INDICATOR
HEATING ELEMENT NON HEATED SEAT
FRONT LATERAL AIRBAG WITHOUT FRONT SIDE AIRBAG
PASSENGER AIRBAG NO PASSENGER AIRBAG
EQUIPMENT PACK W/O EQUIPMENT PACK
COURTESY LAMP FRONT DOORS CONT - FR+RE INTERIOR LAMP
HEADLAMP HEIGHT ADJUSTER MANUAL HEADLAMP ADJUSTMENT
FRONT SEAT GUARD WITHOUT SEPARATION GRILLE
RADIO RECEIVER RADIO EQUIPMENT
REFRIGERATION SINGLE AIR CONDITIONING
CRUISE CONTROL WITHOUT SPEED CONTROL
DRIVER’S SEAT HEIGHT CONTROL PARALLEL DRV HEIGHT ADJ
AIR CON./TEMPERATURE REGULATION WITH REGULATION AIRCON/TEMP
CARPET COVER W/O CARPETMAT
DRIVER AIRBAG NO DRIVERS AIR BAG
CARPET DILOURS CARPET F330
WEAR INDICATOR W/O BRAKE WEAR WARNING LIGHT
INTERIOR PROTECTION W/O PROTECTING NET
SWITCH NO CODED IGNITION
COOLANT LEVEL WARNING LAMP NO WATER LEVEL WARNING
TRIM ADAPTATION WITHOUT MOULDING ADAPTATION
LOCKING CONTROL SIMPLE CENTRAL LOCKING
STEERING WHEEL RUBBER STEERING WHEEL 3 BRANCH
STORAGE SPACE LOCKS LOCKING GLOVEBOX
FAN 1 FAN , 2 RATES
Electrical
ALTERNATOR ALTERNATOR 80 AMP
HORNS HORN STANDARD
BATTERY BATTERY L1 250
STARTER MOTOR STARTER MOTOR CL 2
SPECIAL LIGHTING WITHOUT PARTICULAR LIGHT
Component manufacturers
Miscellaneous
SPECIAL SPECIFICATION STANDARD
ATMOSPHERIC CONDITIONS DUSTY ATMOSPHERE
SIDE IMPACTS DOOR WITHOUT REINFORCEMENT
SET OF KEYS 1 I/R PLIP KEY + 1 PRINC UNIQ KEY
DOOR SEAL WITHOUT SEAL DIRT EXCLUDER
SURFACE CONDITIONS UNEVEN TERRAIN
SPEED MONITORING WITHOUT SPEED CHECK
SLAVE CONTROL UNIT 30 FUSES BOX
EMERGENCY WARNING TRIANGLE WITHOUT WARNING TRIANGLE
