well lads what you recon on the replacement metro passing its mot 1st time?
that depends.. how friendly are you with your mot tester
With the amount of work you've done, and your tester that loves the Metro (assuming you're still using him) then probably a clean pass!
(01-10-2014, 03:37 PM)Toms306 Wrote: [ -> ]With the amount of work you've done, and your tester that loves the Metro (assuming you're still using him) then probably a clean pass!
Well he did look after the old one, but will he do the same for this one. that's the thing!
Depends if the head gasket lasts long enough for them to mot it
(01-10-2014, 03:43 PM)Chris_90 Wrote: [ -> ]Depends if the head gasket lasts long enough for them to mot it
already done on this engine chris
balljoints, rear suspension arms, front to rear brake pipes...........................
failed its mot, not sure on what on yet, haven't got the car back yet.
Bad luck pal
hope its noting much
got it back, and its failed on bodywork, the floors and sills! who ever did the arches has bodged the sills with filler. I scrapped the gta for practically less if I think about it enough!
Ah that sucks procta!
I'm sure you could do another reshell over the weekend though!
(02-10-2014, 12:27 PM)Toms306 Wrote: [ -> ]Ah that sucks procta!
never thought of that haha!
