I know this has probably been covered before. Is there anything needed to fit 205 speedlines to my '6'? Spacers? Wheel bolts? Etc. Cheers
Bolts straight on with old style flat bolts, weights may catch on the callipers tho. them balanced with weights on the inside only
will be fine as long as your beam isn't cambered, could do with 5mm spacers on the back but i never ran them . . .whhel weights sometimes catch for about 5mins then they don't after being worn down . .
I ran them on two 306s fine. Nothing needed you need the bolts though. I just so happen to have a set...
What's the difference between the bolts for my clones and the bolts needed for
speedlines?
(30-09-2014, 09:44 PM)willJspears Wrote: [ -> ]What's the difference between the bolts for my clones and the bolts needed for
speedlines?
None mate, they're the same
