cant get my fog lights off can someone help, cant figure out how to get them out
What phase? And what have you tried already? You usually take the connector off and take the screws out
phase 1 and der is only 1 bolt holdin them on (or so i can see) even wit the bolt off the fog lamp wont come away from the bumper its really puzzling me!?
probably be faster to take the bumper off then you can see all the bolts
how would i go about doing so?
3x13mm nuts either side on the lower slam panel, you need to go from the inner archs n/s is quite easy to access o/s a wee trickier unless you remove the washer bottle or your used to not being able to see
Take the nut off the bottom, disconnect the wiring and wiggle them out..
3x13mm? Is it different on the ph1s? Every 306 i've worked on it's 2x10mm each side.
(26-09-2014, 12:26 PM)Poodle Wrote: [ -> ]3x13mm? Is it different on the ph1s? Every 306 i've worked on it's 2x10mm each side.
different yes mate . .
